92 explorer
Old 01-14-10, 07:17 AM
L
92 explorer
How to drop tranny pan on 92 explorer
Old 01-23-10, 06:03 PM
Speedwrench's Avatar
loosen all of the bolts about 3 turns and place a large pan under the trans pan then remove all but the 4 corner bolts use a gasket scraper to gently pry down on the edge of the pan on one side or the other and let the fluid drain for long enough to stop dripping then finish removing the pan and carefully scrap the remaining gasket from the bottom of the transmission housing, don't gash the aluminium or it will leak.
murphy was an obtimist
