Remove CR-V clock
Old 01-16-10, 04:01 PM
daswede's Avatar
Remove CR-V clock
2000 Honda CR-V with a intermittent illuminated clock light.
I'd like to remove it but would like some input on how. Its dash mounted with a plastic bezel holding it in i think.
Old 01-16-10, 04:47 PM
If no one knows...
Information on how to remove any part on the car would be in a factory service manual set of books which you can order from a dealer.
Or you can go to a wrecking yard and find the same vehicle, then many times you can find a car where the dash is mostly taken apart and see how everything goes together / comes apart.
Old 01-17-10, 07:08 AM
Hi Bill,
There are small clips behind the plastic bezel holding the clock in place. Simply pop the clock out by gently prying with a thin butter knife. I recommend doing it in a warm environment if possible as to aid in removal and prevent plastic from cracking. Then is is simply a matter of unplugging the clock and removing it from the bezel (2 screws). Detailed instructions are available here If you are looking for a repair service, I offer one at autoclockrepair.com
Thanks and best of luck!
Steve
autoclockrepair.com
Hundreds of clocks repaired worldwide.
Old 01-17-10, 07:51 AM
daswede's Avatar
Thanks for your replies,especially satitus for your removal procedure.
Nice site
Old 02-17-10, 09:02 PM
Glad I could be of help. More detailed removal instructions coming soon. Also just added more shipping options. Please drop me a note if you have any more questions!
Steve
autoclockrepair.com
