Battery or Solenoid?
Old 01-28-10, 04:18 PM
rdn2113's Avatar
Hi all,
1994 Plymouth Grand Voyager SE - the past two days when I turn the ignition key sometimes it starts right up (meaning there is no delay or long crank time) and other times the engine does not turn over - basically the starter does not engage at all.
I'm thinking solenoid, but I'm not sure. any thoughts?
Thanks!!!
Old 01-28-10, 04:35 PM
P
Check the simplest things first, such as the battery cables. If there's any corrosion on the terminals it could cause what you're describing.
Old 01-28-10, 05:06 PM
rdn2113's Avatar
Thanks Pecos - yes I did check the battery and the cables. Connections are solid and no corrosion at all - everything is clean.
Old 01-28-10, 06:03 PM
F
If I had to choose.....
Solonoid
Because of the intermitent operation.
Batteries, in my experience, go out with some consistancy.
And solonoids go out intermitently.
Old 01-28-10, 06:58 PM
Try wiggling the shift handle while trying to crank it, could be neutral safety switch.
Mike
Old 01-29-10, 04:45 PM
B
If you want to know what the problem is for sure, use a multimeter for testing...
How to use a multimeter...
how to use a multimeter on a car - Google Search
Old 02-05-10, 06:17 PM
automd's Avatar
do you hear any clicking noise? if you do, the clicking that is heard is the solenoid. But low-voltage either from a drained battery, bad battery or poor connections can cause this, most of the time if the vehicle can be jump-started the starter is fine. This would also indicate that the connections to the starter are good.
