Need help on taking of broken central silencer of muffler
Old 02-27-10, 05:40 PM
1990 Honda Accord 4Dr, LX, AT, 203,000 miles. Central silencer of muffler break into two pieces. Tried to take it off, but screws and nuts are rusted. I used WD-40 and it didn't help. I don't know whether liquid wrench will help or not. Does anyone have any suggestions or tips? Thanks!
Old 02-27-10, 05:58 PM
hopkinsr2's Avatar
Chances are you'll need an Oxy-acetelene torch to cut the bolts,, (or a cut off wheel to split the nuts) Good Luck,,, Roger
Old 03-23-10, 12:02 PM
I used grinder and cut off wheel to cut off 2 out of 3 bolts. Used air impact wrench to loose the 3rd bolt on top after removed two exhaust system hangers and 2 bolts that tie to the muffler. I should have use air impact wrench in the first place which may not end up with cut them off. Installed a new central silencer. Since 2 bolts were cut off and cut off bolts can't be removed, I used muffler patch to hold these 2 bolts. It runs for a week so far and everything looks normal.
