Fuel Gage Vibration
Old 02-28-10, 12:50 PM
Fuel Gage Vibration
I have a 1997 GMC Surburban (1500) I had the fuel pum replaced about 4 months ago. Now when I start the truck the fuel gage needle bounces back and forth then settles where the gas is, but the needle is vibrating back and forth. Any solutions? Thanks
Old 02-28-10, 01:51 PM
Was the fuel pump job a DIY or shop job? Sounds like the harness wasn't "rewired" properly with the new pump there is always a new harness and either not replacing it or a loose connection from replacing it will cause the flux you describe.The other option is a gauge going but since its been going since the pump replacement sounds like an intermittent/weak connection thing to me.
Good Luck
Old 03-04-10, 01:54 AM
automd's Avatar
ive heard the the gauge cluster can go bad causing the fuel gauge to vibrate or have erratic movements.
