120k miles, now what...
Old 03-07-10, 12:14 PM
DBR35's Avatar
I have a 2005 Ford Escape with 120k miles. I get regular oil changes every 5k, and my last major service was a 75k scheduled maintanence. The thing is running terrific, and I want to keep it that way. I'd like to put some money into it to keep it running as best as possible, as I don't plan to get a new car in the near future. I can put about $500 into it, what should I have done?
Old 03-07-10, 02:54 PM
Tolyn Ironhand's Avatar
I say keep your $500 and keep doing what your doing. If your Escape is due for any maintenance, do that.
Old 03-07-10, 03:06 PM
If it was me, and it never had a major tune-up, I would opt for new plugs, wires and a rotor/cap if a used.
you know they are not as good as new and will continue to deteriorate and cost you some money until you have a unanticipated failure.
If you have a regular, honest mechanic, tell him to watch for other things like fuel filters, serpentine belts, hoses etc. when he does any other associated work.
I was worried about a bad serpentine belt, but he said it O.K. When I had an unexpected problem with the legendary GM manifold gasket problems, he replaced the belt for the cost of the belt since it was easy at the time.
Do what you should and try to look ahead.
Dick
Old 03-08-10, 02:36 AM
I would stick to the basics
Fluids
Transmission fluid change and filter
Brake fluid change.
Old 03-08-10, 04:15 AM
the_tow_guy's Avatar
Took a peek at the Gates site for timing belt info and it only lists 2001-04, so I would assume you have a chain - good news.
FWIW I've towed very few Escapes, although I did an '05 last week with a blown tranny @ 150,000 miles.
Old 03-09-10, 10:34 PM
Here is Fords 120k service sched.
Inspect
Brakes and Traction Control
Inspect brake pads, shoes, rotors, drums, brake lines and hoses, and parking brake system for all operating Conditions.
Cooling System
Inspect cooling system and hoses.
Drive/Propeller Shafts
Exhaust System
Heat Shield, Exhaust
Steering and Suspension
Inspect steering linkage and suspension.
Wheel Bearing Notes
Inspect wheel ends for endplay and noise.
Lubricate
Control Arm Notes
Lube front lower control arm and steering linkage ball joints with zerk fittings, if equipped.
Replace
Air Filter Element
Cabin Air Filter
Replace cabin air filter, if equipped.
Engine Oil
Replace engine oil for all Special Operating Conditions.
Fluid - A/T
Replace automatic transmission fluid on all transmissions.
Fluid - M/T
Fluid - Transfer Case
Replace transfer case fluid.
Fuel Filter Notes
Replace fuel filter. All Operating Conditions.
Oil Filter, Engine Notes
Replace oil filter under all operating conditions.
Spark Plug (E) Notes
Replace spark plugs.
Rotate
Tires Notes
(S) = Service Warranty Requirement
(E) = Emission Warranty Requirement
(B) = Both Service and Emission Warranty Requirement
Hope That Helps ya out
Good Luck
Old 03-10-10, 07:52 AM
Service checks
Usually your factory service manual will only identify maintenance schedule to a certain mileage (100,000 miles for instance). After that point you can just start from the beginning of the maintenance schedule again.
there a are a few things you can look for that might not be in the maitnenance schedule but will extend the life of your vehicle. Look through your schedule and see if these items have been taken care of or not.
Fluids: Fluids deteriorate over time and need to be replaced to extend the life of the vehicle. If there's a fluid you've never flushed and replaced then go ahead and do it
Pumps: pumps will eventually go bad. Water pumps are the worst cause they're expensive and leave you stranded with no warning. If it's still your original I'd replace it.
Idler pulley: Idler pulleys automatically adjust the tension on the serpentine belt. If the pulley gets worn the belt will jump and could cause damage. Get it replaced at least every 10 years
Radiator caps can go bad without warning and leave you overheated on the side of the road. Keep a spare in the glove box.
Old 03-10-10, 09:15 AM
Beachboy's Avatar
I turned over 300,000 miles on my 1999 Mercury last week, and it is running great. My secret? Other than mostly highway driving (100 miles daily to work), I have faithfully followed the service recommendations in my owners manual. I have the automatic transmission serviced every 30,000 miles and the coolant changed at the same time. For the first 250,000 miles, I had the oil changed every 3,000 miles, since then, I've increased the interval to 5,000 miles.
I have had only factory parts installed on my car. I don't have a lot of faith in aftermarket parts, as many of them appear to be made overseas nowadays.
I drive sanely, at or under the speed limit, with no hard acceleration. I keep the rev's under 2000 until the engine warms up, and even then, I have a self-imposed "red line" of 4,000 rpm on the engine (tach redline is 6,500 rpm). I've never given the car full throttle in its life. "Spirited driving" translates to higher maintenance and less life in my opinion.
At 300,000 miles, the only unscheduled repair I've had to make is to replace the alternator one time. Brake pads have been replaced once, as have rotors. Exhaust system is original, as are all hoses.
I don't use any fancy synthetic motor oil. I've always used Motorcraft semi-synthetic 5W-30 along with Motorcraft filters. My dealer has done all the servicing, as that is the most convenient for me.
I think almost any vehicle is easily capable of at least 200,000 miles nowadays and 300,000 miles or more is reasonably attainable in my experience. And this can be done with ALL brands of vehicles, not just Asian ones. My prior car, a BMW 325e had 253,000 miles on it when I traded for the Mercury, and it looked and ran flawlessly. I probably traded it in far too prematurely.
Old 03-16-10, 07:35 PM
DBR35's Avatar
Beachboy, you sound like the Mother Teresa of vehicle ownership...
Old 03-18-10, 04:26 PM
Beachboy, you say you have had 1 brake job inside of 300k miles? I think that's incredible.
