3.3L 95 caravan has its moments where it sputters and has no power.
Old 03-25-10, 06:09 PM
BLD
BLD is offline
My first thought was to change out the cap and rotor, But this car doesnt seem to use a cap and rotor. Is there anything else in the electrical system that could cause it to lose power and sputter?
I have been feeling it starting to run rough for a week now but today I had several moments where I had to limp back to the driveway.. Only to be drivable an hour later.
Old 03-25-10, 07:05 PM
Have you cycled key to retrieve trouble codes from dash yet?
When was fuel filter changed last? Had fuel pressure tested when it starts to run bad?
Old 03-26-10, 12:07 AM
Mike hit it if you can get trouble codes that would help me.The symptoms are a little general could be a coil pack breaking down,fuel issue thinking pump right now,bad O2 sensor leaning it out to much or over fueling. TPS well you get the idea kinda need more input to help you sorry will check back later.
