2004 Grand Cherokee left brake light
Old 03-30-10, 01:37 PM
wsaend's Avatar
It doesn't work even after replacing with new one. Any idea's before I take it to shop.
Old 03-30-10, 03:31 PM
wsaend's Avatar
Update
It is real dim when the head light are on and semi dim when the headlights are off. I heard this can be a problem with the GCs. Not found a fix.
Old 03-30-10, 04:49 PM
May be a poor ground? See what happens if you run an alternate ground to it.
Old 03-30-10, 05:11 PM
wsaend's Avatar
You were right about the ground. It was actually the plastic ring that holds the receptical in place must had heated and melted a bit. So I had to basically break it so the tab would pop up a bit more and get better contact with the ground. The tab was melted to the ring and therefore bad contact. Thanks for the help.. This is a problem for the jeeps and there are many more electrical problems I had to fix.
Old 03-30-10, 05:36 PM
Glad you got it fixed. On to the next problem..
