2004 Suburban Trailer Running Lights
Old 04-06-10, 08:25 AM
I have no running lights on the trailer. Turn and stop work fine. I found the 15 amp fuse for the trailer park lights and it is fine, but there is no voltage in the fuse socket. Vehicle running lamps work fine.
Park lamp relay has only 4 terminals, so I don't think the trailer circuit is separate, but I'm not sure where to look next.
Old 04-06-10, 04:55 PM
For that I would haul out the factory service manual set of books (order from helminc.com) and look at the wiring diagrams section(s) to see how it works. What all is involved with the circuit.
Some of these truck/burb trailer wiring systems can be quite complex, especially when you factor in a 2nd battery for this in the truck/burb.
Also be aware in some of these vehicles there can be 3 different fuse boxes as well as fusible links (special wire which is itself a fuse). This would be engine compartment, inside drivers side, and inside passenger side.
And all the wiring to all this stuff is all wrapped up in bundles. Impossible to trace any wiring to see where it goes! So need to pull out the "books"...
