2000 camry solara fan speed problem
Old 04-06-10, 11:10 PM
Hi All,
Interesting new problem that popped up today, climate control fan no longer turns on unless in the third position (1-5 speed possible), AC/defrost turns compressor on in 1-2 position, just no fan until position 3. Pretty annoying since position 3 blows too much air for most usage, anything I can check for to get back the slower fan speeds?
Thanks!
Old 04-07-10, 07:03 AM
Sounds like it could be a failing blower motor resistor if the car has only manual HVAC control. Often when these fail they start to drop the low fan speeds. The resistor shouldn't cost over $25.00. Likely located on the passenger side behind the glove box near the firewall. Probably 2 screws and a wire harness plug once you get to it. Not sure about the Camry but some do require a little gymnastic contorsions to get to them from my experience.
Old 04-07-10, 06:55 PM
Thanks!
Yes it is manual control
I'll check it out
