All about: Dodge Caravan 2007......
Old 05-04-10, 03:12 PM
Smile All about: Dodge Caravan 2007......
I have 6 cyl. engine one. Problem? How do you fix the low & decreasing A/C temperarure of this car? What the right freon Will I used? & How to do it?
Old 05-05-10, 01:00 PM
Front only or Front and Rear A/C? the amount of R134 is different between the two. Also need to know if you have single or dual climate control.You could have a number of things causing your troubles from divertor doors to low refrigerant levels.Also in the mix would be temp and sun load sensors,plugged components causing the system to "freeze up"due to moisture in the system.Get me a better description of the system and what you have going on and I'll try and help out.
