powerwindow won't go dn 86f250
Old 05-08-10, 02:18 PM
rt power window won't go dn (up is ok)(clicking). Drivers switch won't operate rt window up or dn...
Old 05-08-10, 03:07 PM
hopkinsr2's Avatar
I read your post several times,, The window wont go down?? Or it won't go up OR down??? You say drivers switch won't opreate it,, but does the right switch work it??? Give us some more details & we'll go from there.... Roger
Old 05-08-10, 03:38 PM
badeyeben's Avatar
Ford power windows are known for the gears going out in them. Check at the auto parts near you for the kit to rebuild them. Not a hard job to do.
Old 05-08-10, 04:21 PM
mickblock's Avatar
So the passenger window will go up but not down using the passener side window switch, but no response at all when using the driver side switch? Can you use the rear window switches to operate the rear windows?
Check the child safety feature on the driver side switch bezel. If it's on you'll get this limited functionally of the widows. If that isn't the problem remove the bezel in order to verify that the electrical connection is not loose. If you have a multimeter you can set it to check continiuty and check the switches themselves. They should give a reading when activated.
Old 05-09-10, 07:56 AM
clarifying on this old 1986f250 std cab pu
rt window switch clicks but won't go dn-will go up.
remove motor an cleaned and tested with 12 volts-works in both directions.
owm meter and test lite no help to me.
The drivers (Lf) multi switch does not even click rt motor.
Suspect one of these switches is bad but hate to buy both as a tester .....thx for listening
Old 05-09-10, 08:37 AM
hopkinsr2's Avatar
Check the wires between the door & the body of the truck,, After lots of opening & closing,, these wires can break & do strange things... Kinda sounds like what you've got going on??? Roger
Old 05-09-10, 08:53 AM
mickblock's Avatar
It does sound like a loose connection. You know, you can test the switches by testing them the same way you would a light switch. And you can test the terminal ends of the incoming wires for voltage.
But you say that the ohm meter and test light is no help to you?
Old 05-15-10, 04:48 PM
.....i gave up trying to isolate problem and installe a "reverse polarity switch" $10...........works good
Old 05-15-10, 08:25 PM
Question
just for future referance-?
what did you install /where as a "reverse polarity swtch"
Old 05-26-10, 05:07 PM
googled "reverse polarity switch" ....it sent me to a $10 switch (6 hookup on back of a toggle switch) i picked up a 12volt source behind door panel and wired....the switch i put in place of the original window switch (made small bracket)
If you want the "STANDARD" auto parts ....part number i will get it for you?
Old 05-26-10, 05:33 PM
NEsportsfan's Avatar
How does the regualtor cable tangle into knots? Got a 95 Crown Vic, I did replace the regulator with help from a friend.
Trackbacks are On
Pingbacks are On
Refbacks are On
