2003 chevy cavalier crazy gauges
Old 06-09-10, 03:14 PM
All of the gauges have gone crazy. Tach, speedo,temp,amp all read way off. Mostly pegged all the way. Thanks
Old 06-13-10, 02:11 AM
most likely the cluster has some internal failure, the gauges are controlled by it internal logic board via a communication bus called class 2 data, I would try disconnecting the cluster or pullling its B+ feed fuse to see if that resets it. If not then you'll have to replace it.
Note, the radio, the HVAC and everything else works ... right?
Old 06-13-10, 08:29 AM
Correct, only the gauges.
