gas hand is not reading correct
Old 06-27-10, 05:58 PM
Angry gas hand is not reading correct
when their is a half of tank of gas my gas hand want to stay near the E some time it will read like it should most of the time near the E if it my sending unit would i have to drop the gas tank to the ground to replace the sending unit(1993 Ford Explorer 4.0 V-6 engine)some time the check engine come on and go back off.were is the sending unit located at?
Old 06-27-10, 06:18 PM
mickblock's Avatar
It's most likely the float. Which I believe is a separate replaceable part of the fuel level sending unit.
Yes all that good stuff is part of the fuel pump aperture inside the gas tank. If you grab a repair manual from the library you can verify this as well as access repair instructions.
Old 06-28-10, 06:20 AM
mickblock's Avatar
A typical fuel pump. This one is from a 2002 Ford Focus
Sending unit detail
There you go. But a repair manual will still be necessary for diagnosis/replacement procedures.
Holler back if you've got anymore questions.
