Knock sensor/o2 sensor/engine cleaner Q's
Old 07-14-10, 07:01 PM
C
1) What does my knock sensor actually telling me when the check engine light is on? Cleared the code and it came back 2 days later
2) when using code scanner for the check engine light, the scanner one O2 sensor was running rich and the other was running lean--should I warranty these two out.
3) anyone know of a good motor cleaner--like sea foam???
Old 07-14-10, 08:17 PM
N
what are you working on??
what codes are you geting?
the knock sensor just tells the pcm-something is wrong
