Can't find the fuse
Old 07-28-10, 11:56 AM
Can't find the fuse
Does anyone know where the fuse is for the window washer pump in a 2005 Hyundai Tucson (2.7 ltr)? I looked in the driver compartment and the box under the hood and can't find it anywhere. Does that pump run both the back and front washers because neither work? I can't hear it run so I assume its a blown fuse..
Old 07-28-10, 12:30 PM
Gunguy45's Avatar
Super Moderator
Autozone has wiring diagrams...looks like 2 separate fuses...but it appears they have a common relay assy.....
Sorry...looks more complicated than I could help with on the troubleshooting.
Old 07-28-10, 09:18 PM
Also your owner's manual should show the location of all fuse boxes. Some vehicles have a 3rd fuse box.
Also there can be individual fuses and "fusible links". A fusible link is a special type of wire which melts, so the wire would need to be replaced with another special wire.
