Broken heated power mirror glass
Old 08-05-10, 11:34 AM
NEsportsfan's Avatar
Is there a good way to get broken mirror glass out so I can reuse the assembly? It still moves via the switch in the car but the glass is star cracked. I tried using a hair dryer on it to try to heat the glue and a flathead screwdriver to take out the glass, but it didn't work very well. this is for a '95 Crown Vic, which would have been bartered but the other guy hasn't received the title for his car yet from the DMV.
Old 08-05-10, 04:56 PM
Unclediezel's Avatar
The glass comes out with the "Plastic Reciever"
I dont recall offhand-----But I remeber something about prying the outer edge Vertically Toward the door, and popping it out from the other side. Google it, Im sure someone has done it.
Old 08-06-10, 12:31 PM
Thank you much. Probably should buy the new glass to see how it goes.
Old 08-06-10, 01:58 PM
Had a Tempo of something similar year and I recall it basically being a ball and socket joint, the plastic receiver just popped out with a little pressure
Old 08-06-10, 03:49 PM
Thank you much, ordered the part, getting it on Monday.
Old 08-10-10, 11:42 AM
Got the part, it was a piece of glass cut right size and a couple pieces of double stick tape. Cleaned the surface with alcohol, put on the tape and the glass.
