ac clutch in tracer
Old 08-11-10, 06:46 AM
ac clutch in tracer
1998 mercury tracer ac clutch not engaging charge is ok
any thoughts fuse location relay?
thanks
Old 08-11-10, 08:17 AM
The fuse is probably under the hood somewhere. The owner's manual will say fuse locations and fuses, but in general. Might not mention A/C compressor.
Also if the system is low on refrigerant, a low pressure sensor switch will prevent the A/C compressor from operating. Have the pressures checked.
Old 08-11-10, 10:09 AM
ac clutch in tracer
like i said charge is ok no manual checked all visable fuses under hood and inside looking for exact location of fuse and or relay to engage clutch
Old 08-11-10, 10:52 AM
Might try asking here...
Automotive AC Information Forum - ACKITS.COM
Here is a search for the words Mercury Forum. Someone may have the factory manual or know?
Google
If you can't get that information on the internet, it would be in a factory service manual set of books which you can order from a dealer or helminc.com
Old 08-11-10, 09:07 PM
ukrbyk's Avatar
jumps start clutch from battery. for a short time, of course. see if it even engages.
Trackbacks are On
Pingbacks are On
Refbacks are On
