rubbing and CV joint type sound..
Old 08-17-10, 04:11 PM
NEsportsfan's Avatar
This morning my '95 Crown Vic started to make a rubbing sound when I first turned the wheel with the car just after shifitng into DRIVE. It also makes a sound upon turning like a CV joint going south. I did put in some P/S fluid today and it is still making those noises. Any ideas what it can be since I cannot see how it can be rubbing and as far as I know RWD cars do not use CV joints although with this car I wouldn't be entireely surprised if it did. Thank you much for any input. BTW it has 149,500k on it.
Old 08-17-10, 07:10 PM
ASE MASTER's Avatar
Rule out:
Small stones or rocks stuck in the threads of the tires.
Issues with ball joints or tie rod ends.
Bent, distorted or worn front suspension parts.
Old 08-19-10, 01:54 PM
Noises stopped a day later, not sure if it was just a case of the fluid needing to work it way through the rack, because it is quiet again.
