cluch problem 2000 mazda pick up
Old 08-26-10, 10:47 AM
2000 b2500 mazda pick up clutch not disengage. do you need to replace master or slave.
Old 08-26-10, 11:09 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
It could be either...try bleeding the system to see if you get fluid movement...if you don't I'd vote master as first choice. I'm sure a shop could connect a pressure gauge to the hose and test that way.
