Toyota Corolla 2007 LE
Old 08-31-10, 11:47 AM
P
Received 1 Vote on 1 Post
I know to squeeze the glove compartment to get it out to see the cabin filter, but do not see it. Is it horizontal and where is it located? I would think it would be flat and slide in and out but I am missing something.
Thank you
Old 08-31-10, 12:55 PM
ASE MASTER's Avatar
The cabin air filter is behind the glove box. You have to remove the screws holding the glove box and then slide the glove box out. Behind the glove box is a 1 X 8 cover. Remove that cover and you will see a compartment that holds the cabin air filter. Remove the compartment to replace the filter. Its a HEPA filter, so use OE filter.
Old 09-01-10, 08:36 AM
P
cabin air
I think mine is different b/c I remove the glove compartment by squeezing the sides of it until it drops out.
I see everything clearly but there is no cover. I just can't figure where the filter is.
I think you are saying that if I get to it, it is laying flat and I slide it out.
I then should be looking for a about a 3/4 piece of cardboard as a sign that that is the filter. Pretty well hidden.
Old 09-01-10, 10:34 AM
E
Peterr,
Perhaps opening up this web link showing step by step pictures will help.
http://208.104.16.45/IS350/DIY_IS350CabinFilter.pdf
Old 09-01-10, 02:23 PM
P
cabin filter
Very much appreciate your great directions.
This makes it easier.
Thank you.
