What I am assuming is a stuck ebrake
Old 09-02-10, 11:26 AM
D
I am driving a 91 ford tempo. it ran fine earlier with a few kinks and jerks when braking, but the car is very old and finicky. I am pretty sure the ebrake is stuck. the car takes way too much to go and quickly decelerates. the ebrake is completely down but im assuming it may be stuck somewhere else. the car was sitting for a while. when i came home i could smell rubber burning and now there is what looks like burn marks, yellowish tint on the rear passenger side tire only. any ideas? and if it is the e-brake, how can i fix it? please help!
Old 09-02-10, 01:00 PM
ASE MASTER's Avatar
(QUOTE) i came home i could smell rubber burning and now there is what looks like burn marks, yellowish tint on the rear passenger side tire only.
Based on the above, it does sound like the emergency brake is hung up. It has to be evaluated. The cable could be stretched, broken or need adjustment. You should also pull the brake drum on the said wheel and replace and worn or broken brake parts.
