6 cd changer stuck
Old 09-25-10, 12:07 PM
6 cd changer stuck
I'm not sure if I'm posting this in the correct place. I have a 6 CD changer in my 2000 Ford Expedition, it is in my center console - I cannot remove the magazine with the 6 CD's in it from my unit, it appears to be stuck. Can you please help me with this.
Old 09-25-10, 04:22 PM
ASE MASTER's Avatar
Rule out blown fuses and circuit breakers.
From there confirm:
12 volt constant
12 switched
and a solid ground
If all above check out replace changer. Replacing is far less expensive than repairing current changer.
Old 09-25-10, 08:41 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
if it's a stock unit, there SHOULD BE a mechanical release of some sort. everything else has it. if i were you, i'd have inquired at dealership. usually, guys are pretty good with this. esp if you have a good looking wife or are a good looking female urself.
