Super tech motor oil
Old 10-19-10, 01:50 PM
Who manufactures super tech full synthetic motor oil sold at walmart ?
Old 10-19-10, 02:12 PM
the_tow_guy's Avatar
Depending on who you ask, Quaker, Shell, or possibly Warren or Pennzoil. Not sure there's a definitive, discernible answer.
Old 10-19-10, 05:39 PM
Thanks, I was told mobile oil, go figure.
Old 10-19-10, 08:00 PM
I think it depends where you live. Try a search at www.bobistheoilguy.com , I know this topic has been discussed there several times.
Old 10-19-10, 08:58 PM
ukrbyk's Avatar
st fyi
Petroleum Quality Intitute of America
otherwise, looks like it's coming from all over the places. personally, when it was $4 a gallon, i used to use it as a flush oil for oil changes. nowadays, it's almost cheaper to buy quacker state for this purpose, and i have a lot of respect to quaker state.
TECH 2000 SUPER CONCENTRATED FUEL INJECTOR CLEANER -- FIRST BRAND
SUPER TECH GAS LINE ANTI-FREEZE -- CRISTY
SUPER TECH R&O ANTI-WEAR OIL ALL GRADES -- SPECIALTY OIL
SUPER TECH RV WINTERIZER -- QUAKER STATE
SUPER TECH UNIVERSAL PRECISE MIX 2-CYCLE ENGINE OIL -- SPECIALTY
SUPER TECH SUPER CONCENTRATED FUEL INJECTOR CLEANER -- FIRST BRANDS
SUPER TECH GAS TREATMENT -- FIRST BRANDS
SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER -- FIRST BRANDS
SUPER TECH & TECH 2000 WINTER FORMULA -25 WINDSHIELD WASHER FLUID
SUPER TECH & TECH 2000 WINDSHIELD WASH -30F -- SOUTH WIN LTD</a><br>
SUPER TECH & TECH 2000 -20 WINDSHIELD WASHER FLUID -- SOUTHWIN T
TECH 2000 & SUPER TECH SUMMER FORMULA WINDSHIELD WASHER FLUID --S
SUPER TECH R&O ANTI-WEAR HYDRAULIC OIL ISO 46 -- WARREN DISTRIBUT
SUPER TECH BAR AND CHAIN OIL SAE 30 -- WARREN DISTRIBUTION
SUPER TECH UNIVERSAL HYDRAULIC TRANSMISSION FLUID -- WARREN DISTR
SUPER TECH MINERAL GEAR OIL SAE 90 -- WARREN DISTRIBUTION
SUPER TECH SAE 15W40 -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 20W50 OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 5W30 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GENUINE 30W MOTOR OIL -- WARREN DISTRIBU
SUPER TECH AND TECH 2000 30W MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 DEXRON III/MERCON AUTOMATIC TRANSMISSION
SUPER TECH AND TECH 2000 TYPE F AUTOMATIC TRANSMISSION FLUID --
SUPER TECH SAE 30 UNIVERSAL MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH 5W30 FULL SYNTHETIC OIL -- WARREN DISTRIBUTION
SUPER TECH FULL SYNTHETIC SAE 10W30 -- WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND SAE 5W30 MOTOR OIL -- WARREN DISTRIBUT
SUPER TECH SYNTHETIC BLEND SAE 10W30 MOTOR OIL -- WARREN DISTRIBU
SUPER TECH ENGINE TREATMENT -- SPECIALTY OIL CO
SUPER TECH STARTING FLUID -- VALVOLINE
SUPER TECH 50/50 ANTIFREEZE AND COOLANT -- OLD WORLD INDUSTRIES
SUPER TECH TILT AND TRIM FLUID -- WARREN DISTRIBUTION
SUPER TECH MULTI-VEHICLE AUTOMATIC TRANSMISSION FLUID -- WARREN D
SUPER TECH SYNTHETIC BLEND 10W40 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH UNIVERSAL 2-CYCLE OIL -- WARREN DISTRIBUTION
SUPER TECH RV AND MARINE ANTI-FREEZE -- FOX PACKAGING CO
SUPER TECH ENGINE DEGREASER -- HYDROSOL INC
SUPER TECH CARB CLEANER -- HYDROSOL INC
SUPER TECH WHITE GREASE -- HYDROSOL INC.
SUPER TECH MULTI PURPOSE LITHIUM GREASE -- WARREN DISTRIBUTION
SUPER TECH MULTI DUTY COMPLEX GREASE -- WARREN DISTRIBUTION
SUPER TECH MOLY LITHIUM GREASE -- WARREN DISTRIBUTION
SUPER TECH MARINE GREASE -- WARREN DISTRIBUTION
SUPER TECH 0 DEGREE WINDSHIELD WASHER FLUID -- SOUTHWIN LTD
SUPER TECH AUTOMATIC TRANSMISSION FLUID -- WARREN DISTRIBUTION
SUPER TECH 75W140 SYNTHETIC GEAR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GL-5 SAE 80W90 GEAR OIL -- WARREN DIST
SUPER TECH AND TECH 2000 GL-5 85W140 GEAR OIL -- WARREN DISTRIBUT
SUPER TECH FULL SYNTHETIC - ALL GRADES -- SPECIALTY OIL / PENNZO
SUPER TECH OUTBOARD 2 CYCLE ENGINE OIL TC-W3 -- SPECIALTY OIL
SUPER TECH MINERAL GEAR OIL SAE 90 -- SPECIALTY OIL / PENNZOIL QU
SUPER TECH AND TECH 2000 10W30 MOTOR OIL -- WARREN DISTRIBUTION
SUPER TECH SYNTHETIC BLEND MOTOR OIL - ALL GRADES -- SPECIALTY O
SUPER TECH SUMMER WINDSHIELD WASH (WASHER FLUID 32) -- FOX PACK
SUPER TECH +22 F WINDSHIELD WASHER FLUID -- FOX PACKAGING
SUPER TECH 10W40 -- EXXON MOBIL
SUPER TECH 20W50 -- EXXON MOBIL
SUPER TECH R AND O ANTI WEAR HYDRAULIC OIL AW 46 -- SPECIALTY
SUPER TECH SAE 30 UNIVERSAL MOTOR OIL -- PENNZOIL QUAKER STATE
SUPER TECH AND TECH 2000 WINDSHIELD WASHER FLUID -25F -- FOX PA
SUPER TECH WINDSHIELD WASHER FLUID -20F -- FOX PACKAGING
SUPER TECH MARINE OUTBOARD 2 CYCLE ENGINE OIL TC-W3 -- SPECIALT
SUPER TECH MARINE HIGH VISCOSITY 80W90 LOWER UNIT GEAR LUBRICANT
SUPER TECH CORROSION CONTROL AND TRAILER WHEEL BEARING GREASE --
SUPER TECH CONCENTRATED FUEL INJECTOR CLEANER -- PENNZOIL QUAKER
SUPER TECH GAS TREATMENT -- PENNZOIL QUAKER STATE
SUPER TECH POWER STEERING FLUID -- PENNZOIL QUAKER STATE
SUPER TECH HIGH PERFORMANCE BRAKE FLUID DOT 3 -- PENNZOIL QUAKER
SUPER TECH UNIVERSAL 2 CYCLE ENGINE OIL -- PENNZOIL QUAKER STATE
SUPER TECH 80W90 AND 85W140 GEAR LUBRICANT -- SPECIALTY OIL
SUPER TECH MARINE POWER TRIM AND TILT FLUID -- PENNZOIL QUAKER
SUPER TECH SAE 30 UNIVERSAL HEAVY DUTY DIESEL ENGINE OIL -- PE
SUPER TECH PERFORMANCE ENGINEERED HD SAE MOTOR OIL - ALL GRADES
SUPER TECH HEAVY DUTY TRACTOR HYDRAULIC AND TRANSMISSION OIL -- SPEC
SUPER TECH R&O ANTI WEAR HYDRAULIC OIL AW 46 -- SPECIALTY OIL
SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER -- SPECIALTY OI
SUPER TECH TYPE F AUTOMATIC TRANSMISSION FLUID -- SPECIALTY OIL
SUPER TECH DEXRON III / MERCON AUTOMATIC TRANSMISSION FLUID -- SPEC
SUPER TECH BAR & CHAIN OIL GRADE 30 -- SPECIALTY OIL / PENNZOIL
SUPER TECH SAE 15W40 UNIVERSAL MOTOR OIL -- SPECIALTY OIL / PENN
SUPER TECH PERFORMANCE ENGINEERED MOTOR OIL - ALL GRADES -- SPECI
SUPER TECH ANTIFREEZE / COOLANT -- HONEYWELL
SUPER TECH WINDSHIELD WASHER PREMIUM DEICER -30 -- FOX PACKAGIN
SUPER TECH 5W30 -- EXXON MOBIL
SUPER TECH MULTI LUBE -- HYDROSOL
SUPER TECH OIL TREATMENT -- NATIONAL INTERCHEM LLC
SUPER TECH 10W30 -- EXXON MOBIL
SUPER TECH HD 30 -- EXXON MOBIL
Old 10-20-10, 11:31 AM
ASE MASTER's Avatar
(Question) Who manufactures super tech full synthetic motor oil sold at walmart ?
As stated.
Petroleum Quality Institute of America, LLC.
For now.
Petroleum Quality Institute is in bed with a number of other oil companies.
It’s called “Business as usual”.
In the corrupt greed driven “World of oil.” [B
]Doesn’t matter who makes “Super Tech” or where it comes from. [/B]
The only thing that matters is that:
All synthetic oils and fluids are crap and simply a waste of time and money….Ignore the owner’s manual….Change your oil and filter every 3000 miles…. Use only Castrol GTX (organic) motor oil, and use only Purolator Pure One Oil Filters. Post the year, make, and model of your car, and we’ll post the proper viscosity you should be using.
Old 10-20-10, 11:57 AM
Since it is from Walmart, you can rest assured it is the cheapest of that TYPE that they could get to use as a "come-on". I do admit to buying my Mobil1 there because that is where my mechanic told me to go to get it and he buys his there for his perfect, classic, original Corvette Sting Ray. - He even has saved all stickers and maintenance records (full pedigree) to preserve the value. He does not stock it (Mobil1) in his shop because the volume required for his typical customers does not justify it.
Old 10-20-10, 03:13 PM
chandler's Avatar
The only one I use is the 2 cycle oil to boost the sulfur in my diesel fuel. One ounce per gallon of fuel. The older engines can't survive on the 15 ppm mandated today. Wal Mart is the cheapest.
Old 10-23-10, 11:57 AM
Square Head's Avatar
ASE-why is full Syn Oil crap??
I disagree myself.
With Syn Oil, the molecules stay the same size always as they move through the engine and the Visc is way better.
This = better lubrication over all.
Old 10-27-10, 05:42 AM
I believe it's as easy as. Ask why Synthetic Oil was developed?? When? Right after
WWII for use in Jet Engines. Are you using a jet engine in your daily driver? Castrol
GTX has been doing a fine job for me since 1972. D & R it every 3000 miles & fit
a new Wix Filter then at rebuild time you have a clean good smelling engine to
Rebuild. However if you want to spend $7 to $8 a can & $13 for a Racing Filter
don't let me stop you. It's like Restore I try to filter that out while others buy
it to Rebuild their engines. I'f life were just that easy. Ya Think?
Old 10-30-10, 07:53 AM
ASE MASTER's Avatar
Square Head
(Question) ASE-why is full Syn Oil crap??
I disagree myself.
Not just full, but semi, synthetic as well. The answer is simple and oblivious. Both (semi and full synthetic oil create a false sense of security).
In other words
An individual using semi or full synthetic oil is under the impression that they can go 10 to 25 thousand miles between oil and filter changes. It’s not till serious engine damage is done that they realize the mistake they have made.
Want to run semi or full synthetic oil?
No problem.
Just change it and the filter every 3000 miles.
