Car alarm removal
Old 11-14-10, 04:56 PM
Car alarm removal
My friend has a '98 Dodge Dakota and his aftermarket car alarm won't reset. I removed the car alarm from the electrical system and it still wont start even after reconnecting all of the splices.
Is there something else I need to do? The horn honks, the engine runs for about 3 seconds then shuts off. What am I missing?
The alarm was a Chapman system.
Is there a loop plug somewhere or a fuse that must be installed?
Old 11-14-10, 06:37 PM
NEsportsfan's Avatar
Not sure, but it might have a starter kill in there too.
Old 11-15-10, 02:33 PM
ASE MASTER's Avatar
(Quote) Not sure, but it might have a starter kill in there too.
Not a starter kill issue or it wouldn't even crank. The fact that it runs for 3 seconds further proves that.
You have to confirm the method you used to re-connect the “OE” wires. If you simply twisted the wires together and wrapped them with vinyl electrical tape, then you made a mistake. All connections must be soldered and terminated in shrink tubing. If that checks out then focus back on the three seconds. It means that either fuel delivery or spark delivery (or both) to the plugs is dropping out.
Old 11-21-10, 07:45 PM
Fixed it!
All I had to do was turn the drivers side door key to the left then the right to disable the alarm. It runs fine.
