Buick LeSabre Front End Sound
Old 11-28-10, 09:48 PM
My 2000 LeSabre makes a low pitched scrunching sound in the right front wheel well when I brake and the car is moving but only when the temperature is about 40F and lower. As I did a brake job last winter it isn't the brake pads. I assume this is a spring, strut or maybe the rubber coating at the bottom of the spring that has worn down. Does anyone have any ideas on what this might be?
Old 12-17-10, 10:22 PM
sounjds like stabilizer bushings are worn and dried up.
Old 12-18-10, 05:26 AM
Im gonna say check the pads on this one.
Pads vibrate alot after time. Just the way they sit where they are to sit.
The anti-squeel paste they put on can wear off over time.
Personally, I think pads and calipers should be inspected minimum once a year.
I live in Ontario Canada where there is a lot of salt used on the roads and brake parts have a very rough life. The sliders tend to get stuck from corrosion between the anti-rattle clips and the slides on my car. I have to clean them once in awhile.
Old 12-18-10, 07:35 PM
ukrbyk's Avatar
check on rotors. are they glazed? if yes, glaze will cause pads squeal. you'll need to remove glaze.
Old 12-19-10, 04:50 AM
I still say check the front stabilizer bushings. RJ says he hears a low pitched SCRUNCHING sound at lower temperatures and only while moving. I bet you hear it going over a speed bump or in/out of a driveway also.
Old 12-19-10, 02:59 PM
ukrbyk's Avatar
yes, good idea to check anything.
