03 sentra ser P1444 code...
Old 11-30-10, 05:06 PM
Question 03 sentra ser P1444 code...
any ideas what this is for and a possible fix?
Gee
Old 11-30-10, 05:42 PM
The purge volume control solenoid valve is leaking into the intake manifold. This is a very common issue on your car and the reason why two tsb’s are out on the issue. See a dealer for the tsb’s. To be sure that the tsb’s will fix this problem, disconnect the vacuum hose at the purge volume control valve located at the intake manifold. Connect a hand vacuum pump to the valve and apply vacuum pressure. If vacuum is lost or does not hold replace the valve as per the tsb's.
