windshiedl washer question
Old 12-12-10, 12:59 PM
Have a 1997 Lincoln town car and found that the windshield fluid was full but when you pushed the washer button you could hear the clicking but no fluid came out. Since this washer has not been used in probably two years and fluid looks clean, wonder if maybe there is an air lock or what someone might suggest ways of checking what might be wrong. I have never had or heard of a pump failing but I suspect there is always a first time but, may only be an airlock or dirt caught in the line. Any suggestions will be so apprecited.
Dave Doran
Old 12-12-10, 01:46 PM
I've had several vehicles that had the washer pump quit
You might try disconnecting the lines and make sure they are clear.
Old 12-12-10, 03:29 PM
Thanks marksr
Oddly enough we did disconnect hoses etc, found pump was working and after a few more tries we saw liquid coming from one of the connections. I think what may have happened is that we had an air pocket that needed to work its way out. Now the unit works just fine. Since the washers are soooo rarely used, it is possible I guess to have to work the pump a long time to get the air out and move the liquid. Thanks for you help.
