Valve cover gasket '95 saturn
Old 01-03-11, 10:06 AM
I need to replace the valve cover gasket on my saturn. 4 cyl. with DOHC. It appears that I have to pull about a dozen bolts and the cover will come right off. Is that all there is to it? Seems too easy.
Thanks in advance.
Old 01-03-11, 01:51 PM
the_tow_guy's Avatar
Yeah, that'll probably do it. As long as there isn't anything sticking out over it or across it, should come right off. I don't remember the last time I had to look at a Saturn engine; it has that many bolts on the valve cover?
Autozone.com will have the procedure with diagrams in the repair guide section.
Old 01-03-11, 02:06 PM
Gunguy45's Avatar
Super Moderator
Looks like you have 2 different types of valve covers..plastic and alum. Make sure you get the correct gasket and grommets as needed and don't over torque!
Old 01-03-11, 04:00 PM
Thanks guys,
There were only 10 bolts instead of 12. The bolts go through a grommet and they have a shoulder that pulls down against the head so it almost impossible to over-tighten.
Trackbacks are On
Pingbacks are On
Refbacks are On
