throttle/brake adjustment
Old 01-06-11, 12:54 PM
My 2004 Malibu Maxx throttle/brake adjustment has quit working. Everything else is ok. Could it be a fuse? If so, where is the fuse located?
Thank you, FLA. Printer
Old 01-06-11, 04:12 PM
chandler's Avatar
Not up on the new stuff, but what is a throttle/brake? Your fuse panel is most likely located on the driver's side under the hood in a black box with a cover. Inside the cover is the legend of the fuses and what they conrol.
Old 01-06-11, 04:24 PM
probably talking about adjustable pedals
Old 01-06-11, 06:55 PM
chandler's Avatar
I thought it may have been a Jake brake, but not on a Malibu
Old 01-07-11, 04:01 AM
That's what I am talking about....adjustable brake and gas pedals. My wife is short, I am taller: works well for us, except now it doesn't work at all. Thanks for the in-put. Fla. Printer
Old 01-07-11, 05:25 AM
chandler's Avatar
OK, yeah, thanks for that clarification.. Check the fuse panel I mentioned, but also check the one on the inside of the cabin, located either on the left dash where the door closes, or under the dash on the pax side. Your owner's manual should tell exactly which fuse does what, and where the exact locations are for the boxes.
Old 01-07-11, 10:16 AM
Thanks Chandler, fuses check out OK. Guess I'll bite the bullet and see the dealer. Can't win 'em all. FLA Printer
Old 01-07-11, 12:22 PM
chandler's Avatar
Next check the little black blocks in the fuse panel (relays) Most of them will be the same number on top. Swap one for another and see if one of them controls the adjustment control.
