98 Blazer
Old 02-20-11, 09:52 AM
98 Blazer
Son has a 98 Blazer 4.3,Motor is shot ,I was wondering if anyone knows what years of engine will fit
Old 02-20-11, 05:12 PM
ukrbyk's Avatar
Received 20 Votes on 17 Posts
shot in what manner? it's a big motor, it is very hard to kill. or DIY fix is not an option?
Old 02-21-11, 01:26 PM
B
you can fit just about any motor in it. If you want to put a 350 in then you may need to lift the body to for bell housing clearance and a few custom brackets. Or look kit to make another engine fit. If you get a another 4.3 crate motor then that would be an easy weekend or 1 day job. A junk yard motor would run about $500
Old 02-21-11, 01:30 PM
B
I think I understand your question now. You can get any 4.3 with the same injection system. The blocks are all the same. The main things that vary are the pulleys, brackets, etc. Which you will pull off the old block and put on the new if need be. Typically you can get any 4.3 but may have to swap the intake system over to stay compatible with your ecm. There was multiple injection systems on those suv's
