Chevy Tahoe vent controls
Old 02-27-11, 06:27 PM
T
Received 1 Vote on 1 Post
I have a '99 Chevy Tahoe that has a problem with air flow routing. All of my air is diverted to floor vents & I can't get it to switch to my defrost or dash vents. Any suggestions on where / what to troubleshoot?
TexasFire
Old 02-28-11, 04:54 AM
the_tow_guy's Avatar
Received 68 Votes on 57 Posts
Not the most fun to troubleshoot. You'll need to locate the actuators for the blend doors in the ducting. Could be mechanical, electrical, or vacuum-operated. Either you have a bad actuator, or bad signal to the actuator - broken/disconnected cable, bad electrical connection, or vacuum leak. Sometimes all the actuating components will be working perfectly, but there will be a structural failure of one of the doors or its actuating mechanism causing it to remain in one position. I have to warn you, this can be pretty challenging.
