1992 ford probe Brake problem?
Old 03-13-11, 04:02 PM
i have a 1992 ford probe i recently replaced all the brake pads all the way around and put a new rotor on the front left now when i drive or hit the brakes i hear a grinding pulsing sound it also does this when driving straight or turning to the right but when i turn left it goes away unless im hitting the brakes the sound is only coming from the front left side please help
Old 03-13-11, 06:38 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
first thing comes to mind is - who did the job? as if it's a shop, let them have it. if it's you - take it apart and re-inspect.
http://www.ifitjams.com/braking.gif
Old 03-13-11, 06:57 PM
ive already done that about 4 times now also it is not the brakes i completly took off the left front brake caliper and all and it is still making the sound..
Old 03-13-11, 08:13 PM
ukrbyk's Avatar
it does this noise with brakes completely removed on the left side?
Old 03-13-11, 08:19 PM
ukrbyk's Avatar
grinding is grinding. it is piece of metal A dragging against piece of metal B. starts with squeak, ends with grind, as surfaces get rough. there are very few moving parts around brakes that TURN to grind. rotor, pads(relative to rotor), driveaxle, hub bearing. bent dust shield can do this, but it is not relevant to touching brakes.
is front of your engine on the driver, left side? pulleys and all that? it's a Mazda, so clearance between tirewell and pulleys is minute. check on tirewell, if there are any scraping marks on paint. if yes, i'll tell you what to do. does not really make sense this being relevant to brakes, but it depends on powertrain suspension design.
Old 03-14-11, 03:40 AM
yes i think its the inner cv becuase they are old and tore and need replacing im going to replace them tommorow hopefully this fixes the problem
Old 03-14-11, 12:19 PM
ukrbyk's Avatar
that is very possible. those are easy to replace, if you have the right tools.
keep us posted, please. all the best.
Old 03-14-11, 08:39 PM
well it was the wheel bearing when i romoved the axle and the hub the bearing just fell to pieces so now im just reassembling the drivers side and replacing passenger side axle tommmrow
Old 03-29-11, 06:04 PM
well i fixed drivers side wheel bearing however the passengerside cv joint axle nut didnt want to come off so i had to drill it off then the axle didnt want to come out after 3 days of drilling through the axle still didnt come out so i sent it to a mechanic to fix
Old 03-29-11, 06:53 PM
ukrbyk's Avatar
oh my. sorry about this, buddy. axle nuts are tough. next time simply drive to any tire shop close by and ask them to break it loose for you, just enough to drive back home and remove with hand tools.
i have never had axle that i could not pull out of hub. i had one aftermarket that i had to sledge back into the hub, that i did.
oh, btw. if you could not remove driveaxle, you could have removed entire hub with driveaxle and bring it to a shop. or manage with vise etc. had Corolla like this.
