98 dodge caravan
98 dodge caravan
i have a 98 dodge caravan the electric cooling fans will not come on by thereselves
Several possibilities. Either the fans are bad, which is less likely if it involves more than one, or there's a problem in the circuit getting power to the fans. Fuses and/or relays come to mind first. Also in the mix of possibles would be temp sensor(s). Going to need a wiring diagram, a meter, and some electrical knowledge.
The wiring info is available on AutoZone's site in the repair info section, although it's not quite as a good as a factory manual schematic.
