1999 Accord-what does this symptom mean?
Old 04-18-11, 06:08 AM
1999 Honda Accord LX 4 cyl
I have had the following symptom occur several times this month. I will be in city traffic slowing down at a traffic light or slowing down to make a turn. Car cuts off and acts like it was not getting any fuel. Car will immediately restart-no problem there.
Any ideas?
thanks for reading and any ideas on what this problem might be.
Old 04-18-11, 07:03 AM
Gunguy45's Avatar
Super Moderator
Any check engine light? What about gauges and indicators on dash, do they go to their off position like you turned the key off?
Could be an electrical issue that happens when things "shift" forward slightly while slowing? Can you make it happen, or is it totally random?
Old 04-18-11, 07:13 AM
gunguy
thank you for your reply.
to your questions.
no to check engine light. all gauges/indicators go to off position like car is not on.
seems to happen randomly and no, I don't think I could make this happen. absolutely no warning when this event occurs.
Old 04-18-11, 07:21 AM
Gunguy45's Avatar
Super Moderator
Well, the gauges going off really points to an electrical issue. First I'd check your battery cables and connections at both ends. Take them off clean them and replace. Grounds as well.
If that doesn't help, I'd have to start looking at every connector for the ignition and to the computers. Little things like tail lights, radio, interior lights shouldn't cause a shutdown.
Old 04-18-11, 06:01 PM
ukrbyk's Avatar
take EGR valve off and spray clean with brake or choke cleaner.
remove idlse speed air control valve, disassemble, clean, and reinstall. they used to have oddly designed idle control valves that will have coolant lines connected to them, with coolant running through half of it. slime will collect inside and performance goes down.
but awfully sounds like EGR.
btw, even dirty air filter will do this.
and read codes at any parts store.
Old 04-18-11, 06:08 PM
Gunguy45's Avatar
Super Moderator
ukrbyk...
How could those issues you mentioned cause gauges to flatline like the key was turned off?
Old 04-19-11, 06:54 PM
ukrbyk's Avatar
Originally Posted by Gunguy45 View Post
ukrbyk...
they don't. i only read his 1st post. shame on me.
Old 04-19-11, 07:03 PM
ukrbyk's Avatar
now that i read the additional info.
ignition lock? simply cuts off the engine? including dashboard gauges?
seriously, why not to read error codes?
Car starts and runs fine, but once on the move stalls suddenly and randomly. It restarts with no trouble
back to Symptoms
Honda-specific
* Ignition switch
* Igniter
Coil
Loose wire
Starting Problems
Old 04-20-11, 04:24 AM
the_tow_guy's Avatar
Ignition switch was the first thing that came to my mind.
Old 04-20-11, 01:37 PM
ukrbyk's Avatar
fortunately, those are piece of cake to replace on Hondas. ignition switches.
Old 04-21-11, 08:29 AM
thank you for your replies.
after visiting dealer this AM for routine oil chg, I thought I would post update. I discussed symptom with service mgr.
It is ignition switch. Not certain why but service manager says it will be covered under warranty. I did not argue. Part has to be ordered and will be installed next week.
thx again.
Old 04-21-11, 08:54 AM
Gunguy45's Avatar
Super Moderator
Ahhh there was a recall on ignition switches back in 02...that must be why it's free.
Old 04-21-11, 05:24 PM
ukrbyk's Avatar
good for you!!.
gunguy, promise, I will read ALL posts now.
Old 04-24-11, 05:26 PM
tell the dealer to wash your car to
Trackbacks are On
Pingbacks are On
Refbacks are On
