My powerd driver's seat will not move forward!
Old 04-30-11, 03:56 PM
A
I have a 2001 Toyota Solara 4cyl with a powerd driver's seat and last nite after moving it backward it stayed there and will not move forward again. All other movements still work except the forward movement. I don't see anything blocking it and tried forcing it to move and it wont budge. Could it be a fuse or motor??!
Old 04-30-11, 09:43 PM
E
Yes it could be either or both, but did you also check the obvious first to make sure that the harness connector for the seat control switch is well secured in position? I have seen first hand a case where moving the seat all the way back put some tension on a seat control harness that actually caused a switch disconnect. If all seems OK next step is checking the fuse, and hopefully it won't involve anything further around a drive motor.
