01Malibu headlight
Old 05-02-11, 08:17 PM
Question 01Malibu headlight
How do u change a headlight on the drivers side ?Ive already removed the 2 bolts&3 plastic plugs&still dont have access,can anyone help me out?Thanks!
Old 05-03-11, 02:02 PM
I am assuming you took out some screws from the top. Put those back in. Then near the top left and middle you should see a flat blade. Thats a clip you pull straight up. Pull those 2 clips up, they don't pull out all the way. Then the headlight slides right out. The tops of the clips are usually black and about 5mm long parrallel with the ground. They are between where the screws are and the head light lens on top
