1993 lexus gs300 airbag light
Old 06-05-11, 09:08 AM
Question 1993 lexus gs300 airbag light
How do i reset the airbag light on a 93 gs300
Old 06-05-11, 12:36 PM
the_tow_guy's Avatar
Not diy as far as I know. Pretty sure it takes a scan tool. You'll need to get the problem fixed that's causing the light or it'll come back on.
Old 06-06-11, 11:19 AM
ukrbyk's Avatar
check with dealership. passenger safety devices are usually lifetime warranty.
Old 06-19-11, 08:42 PM
billys68ss's Avatar
Airbag systems are not lifetime warranty. Maybe on some obscure vehicle, but I have worked on em all and I have never heard of a lifetime warranty.
Airbags systems are active and run tests on components at key on. If there is a problem the light will stay lit after the bulb check. If the controller does not detect a problem the light will go out. There will be a code regardless. Unfortunately there is no way to determine what the problem is without a scan tool and most aftermarket tools will not pull airbag codes.
Take it to a dealer and get it diagnosed properly as a fault in the restraint system could cause your airbags not to deploy properly in the event of a collision.
Hope this is helpful to ya,
Billy
