96 Blazer runs for a while then won't start.
Old 06-10-11, 11:19 PM
I have a 96 blazer that is running a bit rough. If it sits overnight it will start right up with no hesitations, however after running for a few minutes it starts to run very rough. Once I turn the car off after this it will not start back up unless it sits for several hours. I'm getting fuel. I just put new plugs and wires on it. I checked all the vacuum lines and they're all good. Compression is 120. I also noticed a lot of white smoke coming from the exhaust. Any suggestions would be great. Thanks.
Old 06-11-11, 05:15 AM
the_tow_guy's Avatar
Now did the old plugs look when you pulled them? Check for spark when it won't start. Ignition modules, for one, have been know to cause a hot no-start when they begin to degrade, but there are other potential causes, too.
Old 06-11-11, 07:46 AM
Plugs were dry. No composites on any of the plugs. I checked for spark on all plugs and they all check out.
Old 06-11-11, 09:50 AM
Hi
I know you said it was getting fuel but the first thing that jumped into my mind was fuel pump on its way south
