quick ignition coil resistance question
Old 06-16-11, 07:03 PM
My repair manual says that the secondary resistance on my coil should be between 10.0k and 12.8k ohms. My car, when warm, tests in at 14.7k ohms. As far as I remember it tested within range when cold--will recheck. Soooo time to replace???
(primary and terminal to casing resistances within specs.)
1995 altima gxe auto. 207k miles with a stumbling problem that gets much more evident when car gets warmed up.
Thanx
Old 06-16-11, 07:38 PM
sounds like a good guess/deduction - coil starting to fail - as the temp increases the
stumble increases.
don't know of any more diagnostics on a 95 model besides - substitute a known good one for a suspect bad one
