need help
Old 06-17-11, 02:50 PM
need help
i have a chrysler sebring i cant move the shift gear out of park
Old 06-17-11, 02:54 PM
See if the brake lights come on when the brake lights are apllied
If not then replace the fuse
See if car will shift out of park
Check why the fuse blew
Trailer wire connections are the usual weak link
Old 06-17-11, 06:11 PM
Parking pawl is likely jammed in the trans holding the weight of the car back (do you use your parking brake?).
See if you can get some people to push the car uphill a bit to take the pressure off the pawl and then try shifting it.
