1993 Toyota Camry drivers side power window
The motor works fine, same with the switch. The problem is that the piece that attaches the window mount to the cable broke. Is it possible to just get the plastic piece that snaps into the metal mount?
If it is a cable regulator then it is not repairable. You will not be able to get the part off of a junkyard part without breaking it. If you elect to get a part from a junkyard just remember it is as old as the part you are replacing and likely just as worn. Consider the price of a new part before buying the junkyard part. Some aftermarket parts stores will be able to get you a new part as well but IMO I would call the dealer parts counter first for nothing more than peace of mind. Maybe it can save you a few bucks.
Billy
Billy
