2003 windstar drivers window
Old 07-03-11, 01:44 PM
Question 2003 windstar drivers window
The drivers side window on my 2003 windstar van has a intermitten problem it will stick at the top or bottom but if you slam the door it will start working rolling up and down as long as you do not go all the way up or down with it it will work fine any ideas on what it could be? The switch or relay makes a clicking sound when it does this and also the auto door locks do not work anymore when you put it in gear. any help would be greatly appriecated thanks.
Old 07-05-11, 10:22 PM
IMO it is likely your window regulator drive motor going south. You can either replace the motor, or buy a complete regulator assy with drive motor from the after market and install it. Door lock problem is something unrelated I think and possibly related to the Body Control Module, or the how the program is set for example. May need to have a dealer read the BCM for fault codes, but first off check your manual for program settings that may just require resetting.
