1999 Dodge Caravan Airbag light on
Old 07-19-11, 01:31 PM
on my van airbag, abs, brake lights are on and blower fan and radio not working
what should i do where and what fault i should look for
I could not find fuse for radio in fuse panel
Old 07-19-11, 05:52 PM
It sounds to me that it could all be Body Control Module related. You may need to have a dealer read the BCM for diagnostic fault codes as I am not sure if they will come up on a free OBD2 check at the local auto parts store. In case you had not heard of a BCM before, this is a main onboard computer that manages most of the various electrical systems in your vehicle, from the radio to the power door locks and alot more including the air bag system, HVAC, etc.
Old 08-03-11, 12:05 AM
After shutting it off and then starting again after a while it works fine and then suddenly it does again
should i take it aamco to get the obd code
Old 08-03-11, 03:30 AM
Yes, that should be your next step in regards to diagnosis. You need to have a scanned performed at a place that has the appropriate scanning capability to read for any BCM diagnostic codes.
