1995 dodge caravan fuel problem
Old 08-10-11, 06:00 PM
hi i have a 1995 dodge caravan that has a skip mostly when it is idoling i put new plugs an wires and cap and rotor .and a used fuel injector wich is what the code is saying the problem is . but still skips
Old 08-11-11, 08:06 AM
the_tow_guy's Avatar
What code is it showing?
Old 08-11-11, 08:54 AM
There is the possibility that you replaced a bad injector with a bad injector. I don't think that new ones are that expensive off the net. Did you also check the injector wires to make sure they are well connected and in good condition. As the tow guy mentioned, what code is now showing. If there is no code, the next look might be around the vaccum lines. Those hoses are getting pretty old by now and likely original.
