96 Corolla shaking
Old 08-25-11, 09:42 AM
96 Corolla shaking
At speeds over 55, our '96 Toyota Corolla begins to shake and loose power. Can this be indication that we need new cap/rotor and sparkplug wires and/or sparkplugs? The Oil is good, trans fluid good, tires balanced. Any suggestions?
http://images.ibsrv.net/ibsrv/res/sr...ilies/wall.gif
Old 08-25-11, 11:43 AM
the_tow_guy's Avatar
You're probably on the right track. Unless they've been done recently, I would start with the items you named. Even if they aren't the cause of this particular problem, they need doing. I would also add a fuel filter (and air) and check all vacuum hoses. I once went round and round with a '76 Corolla for a simple clogged fuel filter.
