Explorer wont start
Old 08-27-11, 05:50 PM
Explorer wont start
Ford Explorer won't start
1996 Explorer -
Won't start, clicks one time-nothing.
Tried jumping same result.
Cleaned cables, jumped with larger pickup, same result
tested starter at auto parts store - tested good.
Anyone have any ideas. thanks
Old 08-27-11, 07:14 PM
the_tow_guy's Avatar
Might want to temporarily remove serpentine belt (I'm assuming it's serpentine) to see if you have a locked up accessory. Can also get a socket on the crank pulley bolt and see that the engine turns freely (slight resistance due to comnpression). Sounds like typical starter failure except you had it checked; don't know how reliable that check is, though.
Old 08-28-11, 01:03 PM
CasualJoe's Avatar
I'd be suspicious of a bad solenoid. They aren't expensive if you just want to try a new one.
Old 08-29-11, 05:20 AM
Separate solenoid or on the starter? I know old Fords had separate on the firewall, but did they move it to the starter? Been a long time since I did a FoMoCo starter.
Old 08-29-11, 05:52 AM
It was the solenoid on the fender.
Thanks for your help
Old 08-29-11, 11:59 AM
Good. I should have caught that before Joe; my wrecker and both Toyotas have it attached to the starter so I sometimes forget them.
Old 09-17-11, 02:53 AM
Explorer won't start, re:
Take your serpentine belt off and try starting it, believe it or not those a/c compressor's lock up so tight that you would believe your motor has seized up tighter than Sherry's hat band,lol....Bill
Old 09-19-11, 04:52 AM
Note to Bill; see post #5 in thread, it's fixed.
