2004 cadillac door panel
Old 08-30-11, 12:42 PM
B
How do I remove the passenger fron door panel, 2004 Deville DHS? Please
Old 08-30-11, 01:34 PM
the_tow_guy's Avatar
Received 53 Votes on 43 Posts
I don't know specificly how the hardware is on your Caddy, but generally you would need to remove visible/accessible screws holding door handle and control panel, etc. After that usually a simple matter of popping the panel off it's plastic fasteners. This can be down with a special type of pliers or anything with a wide blade like a good stiff putty knife. At some point you would need to disconnect the electrical connector to the control panel, either after getting it loose or after you separate the panel from the door.
What problem are you chasing?
