abs pump 2003 Windstar ???
Old 09-01-11, 02:50 AM
W
Hi - 2003 Ford Windstar 85K, traction control light and check engine light comes on when you accelerate then stays on. Abs pump with computer replacement is what the ford dealer says $1500 + labor...ouch. Are there any other checks that I could do to confirm that replacement is not the only option - Thanks in advance.
Old 09-05-11, 09:27 PM
N
Windstars are known for the tone rings cracking, on the ft c/v hubs - which would set an abs lite / & possible engine lite, what codes are they telling you are coming up ?
what code is being set - to warrant a PCM replacement ??
Old 09-06-11, 09:08 PM
hopkinsr2's Avatar
I have to agree with Newtofta, After working for Ford for ~20 years, I have only replaced 4 or 5 computers,, Check the Tone rings really close, They crack between the teeth & set speed signal codes in both computers as well as other codes.. Post the codes & the Pros will help.... Roger
Old 09-19-11, 08:02 AM
W
Code that comes up is C1095, hydraulic pump motor malfunction...appreciate any fixes
Old 09-19-11, 08:20 AM
N
1st / take elect connector off control module / under vehicle / below driver seat
test to make sure that (i think large yellow) power supply wires have battery voltage.
( a good test is to wire up a head lamp bulb to use as a test light / if the circuit will illuminate the bulb, it should be good enough)
& use the large black wires as your test ground.
in an other words, you must have a good power supply & ground at the module !
also look for corrosion on the terminals ( you are in Canada ?)
Old 09-19-11, 08:56 AM
W
will try this...yes in Canada
Old 09-19-11, 07:10 PM
W
should mention that the
traction control light and check engine light comes on in Drive when you accelerate to ~5 mph, then stays on. So it does not come on if your reverse.
Old 09-22-11, 08:42 PM
N
did you make sure brake fluid is 'full' not , just a little low, a little low will turn both lights on !!
