2001 Pathfinder 3.5 drive belt replacement
Old 09-05-11, 10:02 AM
I've seen many internet posts stating that to replace the 2001 PF belts all you have to do is loosen/remove the adjustment and pulley bolts and swap the belts. How do you then get the belts off/on over the radiator fan that is connected directly to the fan pulley without removing either the fan shroud or fan itself? Thanks.
Old 09-05-11, 10:06 AM
It slips over the fan
Answering my own question here, the AC belt can slip right over the entire fan so it's not a problem. Hopefully this helps someone besides me.
Trackbacks are On
Pingbacks are On
Refbacks are On
